Hy Ciaran i bought j51 madison template and i installed the quick start witouth problem but i have two question for yuo:
1- where can i change the size of the header actually is (i mean div header_bg) 1248*747 and I'd like to have it 1248*500.
I'd like to change and i'd like if don't change when a new release of the will be ditribuited
2- can yuo replace the quick start to the joomla version 3.6.5 actually is 3.6.0.
Thanks a lot and sorry for my english
- alvin77
- Tuesday, 21 February 2017
Hi Alvin
1. Would you have a URL to an example of your header?
2. We are planning to update all demo installers to the latest version of Joomla towards the end of this week.
Hy Ciaran.
Point one solved by myself.
Thanks for the demo installer i will download new pack and install.
I have another question about the style.
1- i'd like to use the grid gallery of nadia free template with madison template buyed.
It work but i can not set a menù iten in link url of the module like i can do with the original grid gallery of madison template.
I found on your forum another issue e i had converted on xml file image_url from text to menuitem.
Now in the module i can select a menù item but in the front end if i select the gri image not open the page.
Probably i have to modify something else in default.php but i don't know what.
Can i do something for this issue?
Hi Alvin
I have amended your module. Could you check for me that it is now as you wish?
Now url link of image tab of the module can set to menu item.
There is another issue now.
Image alt tag,image caption title in tab image and all the setting in tab general of the module are set to menu item "home".
I'd like only url link (tab image1, tab image2,tab image3, etc.)can set to menu item and i'd like the other setting standard as they are when you install the component.
Your module has been amended. Each instance of type="menuitem" has been replaced with type="text" in your modules mod_j51gridgallery.xml.
Hy ciaran probably not undetstand my issue.
I'd like to use with madison template grid gallery of nadia template.
So i bouhgt i downloaded madison template and installed it then i dwonloaded nadia template and install only the grid gallery.
So now i have madison template + grid gallery of nadia template and work good.
Now i'd like that each istance with tipe "text" replaced with type "menù item" (exactly the opposite).
I replaced them in xml file but if i selected an image there is an error page so i think that i have to modify another file to activate the function.
The grid gallery of madison works so and yuo can select menù item like link url.
I prefer the grid gallery of nadia template for my web site and i want that the url link work like madison grid gallery.
Undertsand?
Sorry for my english
Undertsand?
- # 9
Hi Alvin
In your modules default.php (/tmpl - line149) we replaced the following with the current...
<a href="/<?php echo $image_url[$cur_img]; ?>" target="<?php echo $target_url[$cur_img]; ?>"></a> Ciarán
- # 10
We can not understand each other.
I replace the module grid gallery with default setting.
I'd like to have the possibiilty to set only the LINK URL in each tab images (look gallery.jpg attached).
All the other field in tab images and in tab general setting should not be changed.
I found on your forum that must change in modules\mod_j51gridgallery\mod_j51gridgallery.xml:
<field name="image_url1" type="text" default="" label="MOD_J51_MENUITEM" description="MOD_J51_MENUITEM_DESC" published="1"></field>
with <field name="image_url1" type="MENUITEM" default="" label="MOD_J51_MENUITEM" description="MOD_J51_MENUITEM_DESC" published="1"></field>
If i do so when i click on image the page not appears and i have an error probably because there is another file to change.
Now yuo will find all the field set to type=text so the default configuration of the module.
I hope I explained the issue correctly this time
- # 11
Hi Alvin
Sorry to say it is not possible to have different settings (menuitem and URL) between each tab. The same settings have to be used with in each tab. I would suggest using the URL option and simply paste the URL to your article.
- # 12
Hy Ciaran sorry if inherent but i have a local demo with yoru free vitality template and his grid gallery.
With that gallery yuo can in each image tab select a menu item (there are 16 image tab and in each yuo can select).
See the jpg attached where yuo can see that in each image tab only the field linked menù item can set to a menuitem.
Can impossible to do the same thing with the nadia gallery?
I'd like to use this nadia gallery with madison template for my web site because is more pretty but with i'd like to have this feature
- # 13
Try installing the following.. https://dl.dropboxusercontent.com/u/110280303/mod_j51gridgallery_alvin.zip
- # 14
Hy ciaran,
first of all thanks for your patience.
Installed this module and work like i want but not have the same style of nadia gallery
Nadia Gallery is very nice and i'd like to use it.
I can't do nothing to activate the function menù item only for link url (tab Images)?
- # 15
Hi Alvin
Please try installing the following... https://dl.dropboxusercontent.com/u/110280303/mod_j51gridgallery_alvin2.zip
- # 16
