1. erikoraka
  4. Wednesday, 01 April 2020
Is it possible the header area to look like the logo area and the Layerslideshow photo to overlay the header area?
http://stavrodromion.org/el/
Thank you in advance.
Best regards,
Eri
Hi Eri
.header_main {
box-shadow: none;
2. Ensure you have the following in each of your template styles (custom CSS field)...
.header_top {
background-color: rgba(38, 32, 30, 0);
position: fixed;
z-index: 1080;
width: 100%;
3. To amend try adding the following to the Custom CSS field of your homepage template style....
.logo {
padding: 49px 20px;
It is just fine now!
Thank you Ciaran!
Hi Eri
Presuming I understand you correctly, to amend try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
.header_top {
background-color: rgba(38, 32, 30, 0.8);
Can also the photo of the layerslideshow overlay the header area?
I would like the flags to be shown as they lay upon the photo..
Is it possible, i.e. as it is shown on the following link https://www.eriswebstudio.gr/. The photo in this case seems to start from the top of the browser window..
Thanks again,
Eri
Hi Eri
Adding the above CSS to the Custom CSS field should allow the flags to over the slideshow area.
Well, actually at homepage it is ok!
On the other pages I still see the picture below the flags...Please check the url below..
http://stavrodromion.org/el/news/news
Of course to all the other pages I do not use a layerslideshow but a header background image set in the relevant field in the template. Is it possible to fix it there too somehow?
To apply to menu items with no slideshow try adding the following instead...
.header_top {
position: fixed;
z-index: 1080;
width: 100%;
.logo {
padding-top: 90px;
It is ok now, but I noticed the following also:
1. In Homepage I still notice a slight line on the bottom of header-top or top of header-row.. I don't know where it belongs..
Can we make it disappear?
2. Also the flags in the home page do not remain sticky as in the other pages..Can they remain sticky?
[/list]
3. Adittionally, the hornav menu in the homepage is a bit lower that the hornav menu in the other pages..Can we place the hornav menu in the homepage at the same position as in the other pages?
Here's the url of the website: http://stavrodromion.org/el/
Thanks again for your kind help Ciaran!
Best regards,
Eri
