1. fsiconcepts
  4. Friday, 07 April 2017
Hi Ciran!
I like to add header-1 and header-2 module positions to the london template.
The nexus.css contains definitions, but they are not integrated in the layouts.
What is the reason?
What is the best way to integrate them?
I need a module position for multi-language settings in the header area.
You may have a hint, for a better solution.
Thanks in advance!
Hi Fred
We are unable to replicate this issue. Could you post the exact CSS that you have in your Custom CSS field so I can ensure that there is no errors present.
Hi Ciran,
yes, it appears. It's ok.
But the custom css option does no work.
It will not be loaded if YES is set.
I dont want to install a new template version for a second time.
It was just enough to tell me, wich file Need to be changed, to get the custom css file working.
Fred
Hi Fred
Does the logo field appear when you disable the image based logo option?
Hi Ciran
Many thanks.
Please have a look at GENERAL > LOGO from the new LONODON template settings.
I think you have overlooked something. There is no field for LOGO TEXT.
I don't need it, but others maybe.
And I think, the CUSOM CSS Option YES/NO does not work.
Fred
Hi Fred
We have just updated our London template to include a header-1 and header-2 module position in the header area. To obtain this update simply re-download your template from your Joomla51 'My Downloads'.
I have sent you Login data to [email protected] .
Fred
