1. pmgangi
  3. Monday, 17 July 2017
Good Morning Ciaran
I have bought the Harmony Template and successfully installed in the Demo Installer Version. I have some issues which are not clear to me (I could not find a solution neither in the forum nor in the tutorials):
1) I want to add a lot of elements in the main menu but if I do so from the joomla main menu the elements beyond the 9th do not properly fit but in the menu and logo row there is still a lot pf space. Therefore, my question is how to move the logo and the menu in the row in order to be able to use alle the available space. Let me say that I am using Logo text and that for a logo text it seems that the x/y position offset does not work.
2) I have a problem with the logo (always a text logo) mobile version (seen from a mobile) of the website: in the mobile version the logo is not centered and this makes it appear the mobile version of the site wuite unprofessional.
3) I want to delete the bottom links which in your demo are 4 menu and the first one is "
Joomla 51
Joomla51 Home
Browse Templates
Joomla51 Forum
Joomla.org
Buy this Template
4) The photo in the header (in your demo, you have the dish with Chinese food) when I move from the homepage to another page is not resized to a smaller dimension like in your demo but remains exactly like in the homepage. This is a problem for me.
I found:
https://www.joomla51.com/tutorials/item/assigning-the-full-screen-header-option-to-the-homepage-only
but there is nothing like that for Harmony which is not also mentioned in the tutorial but your Harmony demo has that function.
THANKS
Paolo
Hi Paolo
1. / 2. Would you have a URL to an example of your logo/menu?
3. In your module manager (Extensions -> Module Manager) search for the module titled 'Joomla51'. DIsable this module via the module settings.
4. For our template demo we have a module assigned to the 'showcase' module position. which is in the header area of your template. This module is only assigned to the homepage menu item (Menu Assignment0 tab.
Ciaráh
I replied in private to info@joomla51.com
Best regards
Paolo
We have added the following to the Custom CSS field of your templates parameters which allows you to use the full width of the browser for your header therefore allowing you to add more menu items...
#container_header .wrapper960 {
width: 100%;
