Message
OSM_INVALID_SUBSCRIPTION_PLAN
  1. Mol4
  4. Friday, 10 November 2017
Hello Ciarán,
On the website of my client - website - on mobile view the hamburger Menu disappears. I'v tried to find whats going on here but without luck. The template is the same for every page.
Maybe you can give me a hint where to look?
Thanks!
Have you since resolved this issue? On every menu item that we have checked your mobile menu toggle appears to be displaying without issue.
Hello Ciarán,
I haven't resolved the issue.
When I open the site on my iPhone 7 and open the 'News' page I stli miss the menu.
Also when I resize my browserwindow on desktop the menu isn't there, only on the News page.
Greetings,
Ton
Hi Ton
Considering the issue is only present on a single page try disabling any modules on this page and see if this resolves the issue? More specifically ensure that no modules load jQuery which can often cause this issue (Joomla loads jQuery by default).
I've tested some setting and it appears when I use a Menu-link to a category blogview or category tableview the navigation dissapears on mobile.
So can it have something to do with these views?
I've made an extra menu-link: http://www.zoetglas.nl/test and here also the menu dissapears.
Where can I edit the blogview?
Thanks!
I have installed jQuery Easy which ensures only one copy of jQuery is loaded which appears to have resolved the issue.
You appear to have quite a few plugins installed. I would suggest uninstalling any plugins you are not using which would hopefully avoid similar issues in the future.
Hello Ciarán,
Thanks!
I will look into this and clear the plugins that I 'm not using.
Thanks for your time! :D :D
Greetings Ton
