I am building a new site using the Habitat template and I am having a problem with the showcase position opacity.
First off in the template settings, the opacity setting doesn't seem to keep my setting of 0. When I save the opacity it appears to work however, I return to do other adjustments in my template, the opacity setting reverts to a higher opacity again.
Another problem I am having is that I would like to remove the white line that appears when I have a showcase module published, it this possible?
Also I would like to remove the white line on the footer area as well so that just my background image shows without any line on top. Is this possible? Can't seem to find anything that will change this.
I you want to take a look my demo site is at: http://stonyplainwebs.com/
