1. skipper
  3. Wednesday, 11 November 2015
Hallo Ciaran,
as I experienced the template isn't capable to handel mutilingual website.
Do you see a chance to alter the hornav position?
regards
skipper
Not sure I understand your query. Regarding setting up multiple languages you have 2 possible options..
1. Select a Template style in your 'Template Manager' (Eg. Habitat - Default) and duplicate it for each language you want. In each of the styles then select the menus to be displayed for that language. You can then set that template style to the language via the 'Languages' dropdown or by assigning the correct menu items via the 'Menu Assignment' tab.
2. Within the templates parameters you will see an option to convert the menu to a module position. Once selected you can then create a menu for each language set to the 'hornav' module position.
