I am working a website using the Habitat template.
The Grid Gallery is working great when you mouse over using a desktop computer but fails to display text when viewing the website on a mobile device.
Does the Grid Gallery not work using mobile devices other than following a link if touched??
Thanks you.
James
PS: The website I am working on is located at the URL: http://yourcmswebsite.com
- smithjd44
- Saturday, 16 August 2014
Hallo Ciaran,
Thanks, That works. Now I see the caption text always on small device. It's a solution.
Kees
Kees
Hi James
As there is no hover state on a mobile device the GridGallery is limited to just showing the linked image. To change this to show just the text instead try adding the following to the Custom CSS field of your tempates parameters...
.no-touch .j51griditem figure img,
.j51griditem figure.cs-hover img {
-webkit-transform: scale(1.2);
-moz-transform: scale(1.2);
-ms-transform: scale(1.2);
.no-touch .j51griditem figure figcaption,
.j51griditem figure.cs-hover figcaption {
opacity: 1;
-webkit-transform: translateY(0px);
-moz-transform: translateY(0px);
-ms-transform: translateY(0px);
Hi:
I tried the code you said to enter and it's not working for me. I want to be able to see the caption on mobile devices since there is obviously no "hover" ability. Perhaps you can just built this in automatically to the templates.
http://bludovedemo.com/graetz/
Thanks!
Lisa
Thanks!
Lisa
Hi Lisa
Try adding the following to the Custom CSS field of your templates parameters...
.j51gridgallery figcaption {
opacity: 1 !important;
Hello Ciaran
Thank you for the lovely template first of all. I'm working with Calibra, and have the same issue with the grid gallery on tablets (Samsung Tab S 10"
. I've tried adding both the below (singly and together as I wasn't sure) but no effect on my site - I still just get the pictures and no captions.
Could you suggest anything else at all please? The pictures come up and if you click them they go to the right places, but there's just no words to describe what they're for?
I look forward to hearing from you.
My site is http://www.psychic2spirit.com
Many thanks
Liz
Many thanks
Liz
Hi LIz
Try adding the following to the Custom CSS field of your templates parameters which will have the hover state of your images as default (inc. caption) on any touch devices...
.touch .j51griditem figure figcaption, .j51griditem figure.cs-hover figcaption {
transform: translateY(0px) !important;
Ciaran,
Many thanks - that worked a treat.
Thank you for your superb support. B)
Best Wishes
Liz
Best Wishes
Liz
Hello Ciarán
I'm also using Habitat and I have the same problem. On smaller devices the Caption text is not shown. I tried the given css styles. But it won't work.
Do you have more suggestions?
Kees
Kees
.touch .j51gridgallery figcaption {
display: block;
opacity: 1;
- # 11
