MENU
  1. Werner
  4. Wednesday, 01 March 2017
Hi Ciaràn,
after falling back in the Google Rankings I had a look into the Google Cache to check out what Google sees. It looks as if Google has problems to render the file. Can you have a look on the screenshot. What can I do?
Thanks, Werner
PS: Google Pagespeed says: Problems with rendering - will delay rendering.
https://cdnjs.cloudflare.com/…s/cookieconsent2/1.0.10/light-bottom.css and
https://www.kerschbaumerhof.com/…7/0/41068686fb147670a30d3bc75f3eefc3.css. (JCH Optimize file)
Hi Werner
I don't believe the light-bottom.css to be a template CDN call. Would this be from a particular 3rd party extension that you have installed? If so does disabling this module resolve the issue?
Hi Ciaràn,
thank for your response. The Problem was the Module Gtranslate. After removing it, Google could render the page. Unfortunately it can't be loaded async or be deferred...
Thanks, Werner
Hi Werner
Thank you for the update!
