1. erikoraka
  4. Thursday, 25 April 2024
I have the following issue:
I uploaded a module in order the site to be compatible with the EU GDPR consent policy. The module's configuration is found under the menu Components -> GDPR ->Configuration. When I enable the statistics consent category found under the tab Cookie categories, the Great Vibes font I use in the site for H1 style is lost and a different font is shown instead. Can you please advise?
Thank you in advance.
Best regards,
Eri
Attachments (3)
you could also use JT - ALDEF (https://github.com/joomtools/plg_system_jtaldef ) for localizing your fonts
Hi Eri
You may need to localise your Google font. May I suggest the following post on this topic.. https://joomla51.com/forum/localze-web-fonts
It seems that the url https://google-webfonts-helper.herokuapp.com/fonts is not working..
Best regards,
Eri
Hi again Ciaran,
It was a matter of the extension's parameterization. So everything is ok now.
Thank you anyway.
Best regards,
Eri
Hi Eri,
You might try the new URL https://gwfh.mranftl.com/fonts
Regards,
Rolf
