1. webknecht
  4. Sunday, 24 April 2022
another small problem:
In the Emani templates for Joomla 4 it is possible to remove container padding for some module positions like showcase, etc.
But not so for the module position contenttop. So I have a large gap between the module position contenttop and top1 (as per screenshot).
For the top1 position I can remove container padding but this effect only close the gap to top.
I believe that the padding of the contenttop position has to be removed, but what can I do???
Thanks in advance
Hallo !
Grundsätzlich bei Designfragen werden immer Links zur Seite benötigt...
(Auch wenn es in diesem Fall vielleicht von Ciaran hier so gelöst werden kann)
As mentioned, would you have a URL to an example of your modules?
here the URL:
https://www.kaiserpfalz-kaiserslautern.de/
The problem is the gap of the sidecol-1a position
I tried the following in the customs.css:
.sidecol-1a104 {
padding-top: 5px;
But this did not solve the problem
Jürgen
Hi Jürgen
.sidecol-a:first-of-type .module:first-of-type .module_surround,
.sidecol-b:first-of-type .module:first-of-type .module_surround {
padding-top: 0;
thanks a lot it works fine.
Jürgen
it works fine at the starting page, but if choosing another content now the gap is to close!!!
See Here: https://www.kaiserpfalz-kaiserslautern.de/index.php/fuehrungen.html
Jürgen
Hi Jürgen
Due to the following custom CSS, you may need to create a separate template style for the suggested CSS and apply it to the related pages (https://joomla51.com/tutorials/joomla-basics/creating-multiple-template-styles)...
.wrapper_contenttop {
padding: 1px 1px 1px 1px;
Thank you for pointing this out, now all works fine.
Jürgen
