1. salinger
  4. Friday, 02 September 2016
I have installed a photogallery on
http://www.sc-triestingtal.at/joomla3/index.php?option=com_gallery_wd&;view=gallery_wd&Itemid=239#
The buttons are not visible. The developper of the gallery informed me that a code in the template causes the problem.
"In your theme's /templates/j51_enlighten/css/nexus.css file is written this code:
[class^="fa-"]:before, [class*=" fa-"]:before{
color: rgba(0, 0, 0, 0.3);}
This code makes those fonts almost transparent.
If you remove them, all our buttons will look and work correctly."
I found the code and changed it to rgba(0, 0, 0, 1), but that did not help. Do you have an idea?
Thanks a lot , kind regards, Marion
Hi Marion
#bwg_container1_0 [class^="fa-"]:before,
#bwg_container1_0 [class*=" fa-"]:before {
color: #000000;
No sorry, still the same problem...do you need admin access?
regards, marion
Hi Marion
Please. Details can be sent to [email protected]. Please paste a link to this post in your email for our reference.
Thank you Marion
I have amended the suggested CSS to the following which has amended the issue.
color: #AAAAAA !important;
padding: 0;
