1. kvalentin
  3. Thursday, 07 October 2021
hello, i am using the template Emani. It is not possible to edit modules in the frontend (text and pictures). I already updated to the newest version, but the issue is still present.
The website is not online yet, but it is possible to send an user account.
kind regards
Kerstin
Hi Kerstin
Thank you for bringing this issue to our attention. I have just updated the Emani template, resolving this issue and installed the update to your Joomla installation. Your custom module editor should be now displayed with issue.
thank you very much for your outstanding support. It works perfect. Yor are great:D :D :D
Kerstin
As ist seems it is a problem between bootstrap 3 (used by the template) an bootstrap 2 (used by joomla). It seems there is an overrite neccesary for the template.
inbetween i am using a plugin (https://github.com/nielsnuebel/plg_system_nnedittemplate/releases/tag/v1.0.0) which uses other templates for content and module editing as an workarround.
But it seems to work only with the tiny editor and in the case you are edit pictures it is not so perfect....
maybe it helps to solve the problem.
best regards
kerstin
