1. Hedi
  3. Friday, 27 October 2023
With the template Noami for Joomla 4 the frontend editing is not possible.
How can that be fixed?
thanks
Hedi
Thank you for your quick help.
Hedi
Hi Hedi
Could you please detail your issue when editing via the frontend? Testing the demo content of the template, we are unable to replicate any issues editing both modules or components.
I can log in into the frontend. But when I click on the editing button (the field with the pencil) on the side it does not show the space to change the text or whatever I want to change.
Hedi
Hi Hedi
Thank you Hedi
This issue should be now resolved. As you had the component area disabled config component used to edit modules/articles was hidden. To resolve this I have added the following to your template CSS...
.com_config #container_main {
display: block !important;
