1. squirrel333au
  3. Monday, 13 March 2023
I have installed Kunena Forum onto the Nina Template (J4).
It is working fine but when you expand a topic it displays with side modules even though I have set it not to display on those pages.
Hope that makes sense?
Any help or a push in the right direction would help. Thanks
  1. http://angasgokartclub.com/NCMS/index.php/component/kunena/general-chit-chat
  2. http://angasgokartclub.com/NCMS/index.php/forum
Thanks but you do not understand what I am saying, I'm just going around in circles.
I will find a work around or another forum that will fit with Joomla.
Thanks again.
Presuming I understand you correctly, this is not exactly an issue but how Joomlas menu assignment works. Joomla allows you to assign modules to specific menu items however if a page does not have a menu item then the module assignment for the parent of that page is used.
Maybe try creating a hidden menu assignment for your registration page. You can then unassign your module to display on that menu item.
Presuming I understand you correctly, maybe try using the Advanced Module Manager extension which will allow you better control over your module assignment?
https://extensions.joomla.org/extension/advanced-module-manager/
Thanks, but that has not solved the issue.
I am going around in circles trying to solve this issue.
Everyone is blaming everyone else for the issue.
The issue is this...
If a user clicks on the "Create and Account" link from the drop down "Login " the form opens up within the home page with both left and right modules displaying.
The Module assignment has only display all the modules on the Home Page, no other pages.
If a user clicks on "Log In" or "Create an Account" within a topic the right pages opens.
I can not work out why or how to fix it.
Regards and thanks in advance for anyone that can help me.
Attachments (5)
  2. http://angasgokartclub.com/NCMS/index.php/component/users/registration?Itemid=464
Presuming I understand you correctly, maybe tryusing the Advanced Module Manager extension which will allow you better control over your module assignment?
