1. underwatercolours
  4. Tuesday, 31 March 2015
I have a site that uses the Arkadia template. I'm not sure why, but if the wrong CAPTCHA code is entered, the entire form resets and clears everything. Is there a setting where I can change this, or is this not related to the template? I've never seen this happen before.
http://divewithrob.com/index.php/contact
I am not sure if this would be a template related issue. Is the same issue present if you are using one of the default Joomla templates (Beez/Protostar)?
I switched to the Enlighten template and it worked just fine. Then switched back to Arcadia and it worked again. Hmmm
All is well that ends well :)
Thank you for the update!
