1. griffn84
  3. Tuesday, 18 January 2022
I'm noticing that the red color in my footer menu doesn't match the red text in the module next to it. The text in the contact us module is using the text-primary class, which is the color i'd like the menu to be also. I notice that if you hover, you get that color momentarily before it turns the grey hover color.
  1. https://www.advancedtitlegroup.com/
@media only screen and (max-width: 959px) {
.base-2 .j51_inlineicons {
margin-block-start: 1rem;
Hope it’s okay to ask another question in this same thread… I’m using the J51_InlineIcons in the base of the site and on mobile the spacing odd with the text above it. I can’t seem to tweak it to look good on both desktop and mobile. Any idea? (Screenshot attached.)
Appreciate the prompt reply, Ciaran! That worked perfectly!
.module .mod-list li a,
.module_menu .mod-list li a {
opacity: 1;
