1. gradym
  3. Sunday, 08 December 2013
Hi there,
First off thanks for the great templates, I've used quite a few over the years. I am having an issue with the footer in the pianoforte template. I have some info in the 'footer-1' position and there is a sizeable gap between the info and the footermenu which I would like to remove. http://www.centralonstockyard.com.au . Thanks for any help
Could you try adding the following to the Custom CSS field of your templates parameters..
#container_base {
padding-bottom: 0px;
You can further reduce this gap by also adding the following to the same field...
#base.block_holder {
By default each of the above is set to 32px. Hope this helps.
