1. ziggy
  4. Friday, 13 July 2012
I'm working with the Novation template. Can you tell me how to change the font size and 'over' color for the hornav menu? Altering the template.css file doesn't seem to work for changing the color and size.
Is there a particular text you wish to change the font size?
For the hornav menu hover try adding the following CSS to the Custom CSS field within your templates parameters.
[code type=css]#hornav ul a:hover, #hornav ul ul a:hover {color: #AAAAAA;}[/code]
... where #AAAAAA is your new hover colour.
Thank you Ciarán. The custom CSS works. And I put in
#hornav ul a:link, #hornav ul ul a:hover {font-size: 16px;}
#hornav ul a:hover, #hornav ul ul a:hover {font-size: 16px;}
to change the text size in the hornav menu. :)
I would like to change the hornav menu font in the Kontact template. I haven't found a Custom CSS field within the templates parameters.
I tried changing within the following css/template.css code without success.
/* Hornav - Parent Styling */
#hornav ul a, #hornav ul ul a, #hornav .separator {color:#fff; font-size:15px; font-weight:normal; line-height:25px; margin:0 0px 0px 0px; text-shadow:none}
#hornav li {background: none repeat scroll 0 0 transparent; float:left; padding:0; z-index:99999 !important;}
#hornav li a, #hornav .separator {margin:7px 0;}
#hornav li li a {font-weight:normal; overflow:hidden; padding:4px 8px; text-align:left; text-indent:0; z-index:9999 !important;}
#hornav ul a, #hornav .separator {display:block; padding: 4px 9px; text-decoration: none; z-index: 99999 !important;}
#hornav ul ul a {font-size:13px; margin:0px; color:#fff;}
You can try adding the following to the end of your templates template.css (../templates/j51_kontact/css/template.css)...
[code type=css]#hornav ul a, #hornav ul ul a, #hornav .separator {
color:#CCCCCC;
font-size:10px;
}[/code]
Where #CCCCCC is your link color, 10px your link font size.
