Font Awesome J4Naomi
I'm trying to add font awesome v5 in J4Naomi (f.i. fas fa-search), but i just get a rectangle. Tried all variations to no avail.
any idea?
In Naomi J4 1.01 in map css:
files: font-awesome.min.css and font-awesome.css are using Font Awesome 4.7.0
files in map: css|fontawesome are using Font Awesome Free 5.14.0
could did lead to a conflict that is causing the problems?
strange, did that before (vs 1.01) and id didn't work, now it does (thank you)
header of the module is now placed centre instead of on the left. Any idea on how to fix it?
Strange. We have found that some performance extensions can have some funny effects on template CSS. Regardless, to amend try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
