1. ip mann
  4. Friday, 27 May 2016
I'm working with the Grafik template.
I need font awesome icon, "fa-key in the module "login". I used header hlass field in the module settings, but it doesn t work.
Thanks in advance
Iri
http://www.popptraining.at/index.php
Module name: "Anmelden"
Thank you.
Font Awesome does not appear to be loading. To resolve try adding the following to the 'Custom Head Code' field of your templates parameters ('Custom Code' tab).
<link href="https://maxcdn.bootstrapcdn.com/font-awesome/4.6.3/css/font-awesome.min.css" rel="stylesheet" integrity="sha384-T8Gy5hrqNKT+hzMclPo118YTQO6cYprQmhrYwIiQ/3axmI1hQomh7Ud2hPOy8SP1" crossorigin="anonymous">
Now, it works.
Thank you, very much!
