Florence in Firefox looks very different than in Chrome and Internet Explorer. In Firefox there is no right menu, it is a dropdown.
How can I make this menu semi-transparent?
Would you have a URL to an example of this issue? Ensure that you have no zoom set within your Firefox browser as this will trigger the mobile version of the template (CTRL + F5).
I spoke too soon. It has happened again. The left menu has disappeared. I have cleared cache, cookies, tried different viewing magnifications used F5 and it still is not appearing correctly in Firefox. I am using the latest version. I'm happy to send you a link privately.
Your site appears to be displaying correctly however I suspect you are viewing on a relatively small resolution monitor which is triggering the mobile menu. One option to resolve this issue is to reduce the wrapper width which can be set via the \'Layout Options\' tab of your templates parameters.
