1. Darekslim
  3. Wednesday, 23 March 2016
Helo. How to make the template GRAFIK size of a position header and footer was steady and not stretched to fill the screen? It's posiible lest header had as much as a template width is for example 1080 px?? Sorry for my English :)
Presuming I understand you correctly try adding the following to the Custom CSS field of your templates parameters...
#container_hornav, #container_base {
margin: 0 auto;
width: 1140px;
Thank you for answer . I came thanks to your answer that comes to body_bg, I set custom SCC to:
#container_hornav,
#body_bg,
#container_base {
d it. margin: 0 auto;
width: 1280px;
and its almost ok but still my picture is magnified (zoom) the image looks like it was poor value and can not see all of him only in his honor. My header picture is a 1280x400px.
No. localhost. I join images that can will help.
#body_bg, #container_header {
background-size: auto auto !important;
Thank you very much . Now it is Ok. that was it :)
