1. muddasirpk
  3. Sunday, 31 March 2013
We had just buy resonate template , and I have few more queries, Hope you wont mind asking too many queries.
1- I want to add 'Developed By' Text under copyright and bottom menu,
How can I add this?
2- What module class suffix are avaialable (please name) so we can
style our modules?
3- How can I hide social icons on home page only? and display at rest/
4- There is a search box at top, I want to replace that with menu
items, is this possible? if so how?
I had also emailed you the queries so you can either anser me her or at email too.
1. The copright field in your templates parameters except HTML so a new line can be created by adding a line break within the field (Your first line <br /> Your second line).
2. All module variations for this template are available at http://demo.joomla51.com/0092/index.php/features/module-variations
3. You will need to create a new style of the template (Extensions -> Template Manager -> J51_Resonate -> Save as copy) in which your social media icons are disabled. You would then apply this style to your homepage menu item.
4. For details on converting your search field to a module position please check out the following post.. http://joomla51.com/forum/support/commercial-templates/clarity-search-module#2949
Actully, I want to make clickable link at botoom as developed by, How can i achieve this.
Just like in your site you have 'Powered by Kunena Forum' at bottom
As the copyright field excepts HTML you can use...
<a href="http://www.joomla51.com">Your Linked Text Here</a>
I usually create a footer module and modify the en-GBen-GB.mod_footer.ini file so it automatically updates the year. Can I use html code to update the year?
To convert this area to a module a position replace the following near the end of your templates base.php (../templates/j51_resonate/php/layouts/base.php)..
<p><?php echo $this->params->get('copyright'); ?></p>
Replace with....
<jdoc:include type="modules" name="footermenu" />
You can then simply type footer in to the postion field of your module to place it in this area.
Thank you. This worked for the Metropolis template.
