I would like to install in Jasmine the J51 icons- / image hover gallery- and the thumbs gallery-modules.
Unfortunately, it doesn't work. Could you pleas help me? Thank you very much
It seems that your server settings are limiting the file upload.
In your Joomla installation you can check how large it is. ( system | system information | php settings.) You have to increase Upload Max Filesize on your server
Can you confirm that you are uploading the the module install file as these are less than 1MB. Note that you will need to unzip your download before installing the individual modules.
You can see the files in the document below. The icons module is about 1084KB. But I also can't download icons- / image hover gallery- and the thumbs gallery-modules.
Tank you.
download the template file from your template downloads. Extract the zip file. Go to the map joomla 4.x install files. Log into your joomla admin site. Choose sytem | install extension and Upload & Install Joomla Extension each mod_51*****.zip separately.
That does seem strange as your upload dialog states 64MB so uploading a 1MB extesion should not igve you any issues. May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
