1. tbcomputerguy
  3. Tuesday, 26 February 2013
I have the Novation template and I using a menu in the sidecolumn-a position. I would like the menu to flyout instead of just showing the submenus. Is this posible with side menus.
Dave
Hi Dave
By default this option is not available however there is a number of menu module extensions available that can be used to replace the default Joomla menu. For a list of whats available check out http://extensions.joomla.org/extensions/structure-a-navigation/menu-systems
Already on it. I assumed that was the case or else the option would have been there.
Thanks anyways
Dave
