1. staacademy
  3. Friday, 01 July 2016
Hello! I have only been using Joomla for a few years and I would rate my skills as "Google it to find the answer." I am working on migrating from Joomla 2.5 to 3.x and all the updates went smoothly so now I am down to ironing out the template wrinkles.
Here is the current live 2.5 site: http://staahomeschool.com/index.php/placement-support-services
Here is the 3.x site: http://staahomeschool.com/mmp_upgrade/index.php/placement-support-services
Browsers I am using: Google Chrome and FireFox
I installed/updated the 3.x Executive template through Extensions > Manage > Install
ISSUES:
1) Notice the breadcrumbs are now different sized fonts and many have bullet points. I like the little arrow as it was before, but I want to turn off the bullet points.
2) There is now increased space around the breadcrumbs; how do I decrease that so it is like 2.5?
3) The dropdown menus in the top nav bar work in 2.5 and now 3.x; how do I fix those?
4) The search box at the top of the page changed size and looks awful, unbalanced placement of the words, box location, and magnifying glass icon.
I have a few more issues, but my brain will probably explode if I tackle them all at once. Any help or links to articles you can provide to help me refine the 3.x site's appearance will be greatly appreciated.
Thank you!
Bethany :)
Hi Bethany
1. To amend try adding the following to the Custom CSS field of your templates parameters...
.module ul.breadcrumb a {
background: rgba(0, 0, 0, 0) none repeat scroll 0 0;
padding-left: 0;
2. To the say field add the following..
#container_breadcrumb {
margin: -10px 0;
padding-bottom: 0;
3. May I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
4. Also in the Custom CSS field....
#search .inputbox {
height: auto;
width: 200px;
Ciaran,
Your fixes were right on target -- thank you!
I ultimately decided to make the change to Enlighten now rather than later so I'm not sending along an e-mail. But I thank you for your help and the great templates. :)
Blessings,
Bethany
