1. aroldoschwab
  3. Friday, 20 October 2017
Good Morning.
I'm having trouble trying to use my own designs as social icons without being font-awesome.
Is it possible to do that?
How would it be?
I'm waiting.
Hugs
....in time....
I'm using J5-Artisan template ....
....worked perfectly....
Thank you Ciarán ....
Good afternoon Ciarán.
The icons are in PNG (but can be in JPEG too) ....
For images your best option is to use a custom HTML module (Extensions -> Modules -> New -> Custom) and place it in the header-2 module position. Once you have created the module we can give you the need CSS to place the module at the base of the side column.
What format are your custom icons in?
Thank you for your response ....
At first everything working ....
I am waiting for the CSS to put in the base ....
So take a look ....
http://www.emporiumpetshop.com.br
Hugs
.header-2 {
position: absolute;
bottom: 70px;
left: 50%;
transform: translateX(-50%);
@media only screen and (max-width: 1320px) {
.header-2 {
position: static;
transform: translateX(0);
Thank you for the answer....
I'll be putting this up soon and give you the answer here ....
Thanks and hugs
