1. ziggy
  4. Sunday, 20 January 2013
Hi - I just purchased the evolution template and downloaded it. When using extension manager (joomla 3.0) to upload it, it doesn't upload. I used Upload Package File - browse to the .zip file - select it - then hit Upload and Install... and nothing happens!
Am I missing something here?
Hi Robin
Have you unzipped your download? May I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will attempt to install your template for you.
I got it to work, thanks for the reply.
rb
