Warning
JUser: :_load: Unable to load user with ID: 21434
JUser: :_load: Unable to load user with ID: 21320
JUser: :_load: Unable to load user with ID: 20476
JUser: :_load: Unable to load user with ID: 20500
JUser: :_load: Unable to load user with ID: 20709
JUser: :_load: Unable to load user with ID: 20480
JUser: :_load: Unable to load user with ID: 10722
JUser: :_load: Unable to load user with ID: 12128
JUser: :_load: Unable to load user with ID: 18756
  1. youreinlucknow
  3. Monday, 04 March 2013
2 issues:
1. When I view my site (with Evolution template) on an iPhone the header is quite tall. I can adjust the header height and it works/looks fine on a desktop but doesn't change on an iPhone.
How can I make the header adjustment carry over (respond) to iPhone? It's taking up a lot of real estate.
2. My site also goes off the right side of the iPhone screen. It does appear fine on Blackberry devices and on a desktop.
How do I adjust the width or some other setting so that it "responds" to the iPhone and fits that screen width - as well as the other platforms?
The site is: www.MobileBettingCanada.com
Many thanks in advance.
Rob
I was able to get content to fit the iPhone by adjusting the Width % in Template.CSS to 69%. On the mobile phone emulator I use, 69% was the 'zoom' level that fit the content nicely so I used that number. Still looks OK on a desktop and Blackberry.
Maybe there's a better way to do it?
Hi Rob
Your width solution should work fine.
For the header height instead of using the following to adjust the height..
[code type=css]min-height: 108px;[/code]
Try changing this to...
[code type=css]height: 108px;[/code]
This should keep your height the same across all devices.
Thanks. Changing "min-height" to "height" did work....although I have another related problem now....
When viewed with a mobile device the nav menu appears below the header area - on a desk top it appears in the header below the logo. It did it before and it still does that - and that's fine.
The problem is that now when viewed on a mobile, the menu appears over or on-top of the content.
I can't seem to figure out how to fix this. Any ideas?
Hi Rob
Thanks so much Ciaran for resolving the site header/menu issues I was having.
You're the best/
Cheers,
