Hi, I'm using the Everly template with a white menu background and a white header. When you move the mouse over the menu items their is a screen wide dark color that comes over the page.  Is there a way to change the transparent level of that mouseover color/ change mouseover color or remove that feature?.
When using a lighter color header and menu area the dark mouseover color seems opposite of a typical mouseover function to highlight the menu item being "mouseover".
Thanks in advance
Dan
