1. dynas
  3. Monday, 22 April 2019
Hi guys.
I would like to have the transparent header on the front page not completely transparent but I can't find the inline-code.
I would like to have the following css like this:
.header_row, .header_top {
background-color: #0000004d;
Custom css is not working because its inline.
Can you help me
Can you please tell me in which file I can change that?
Thanks a lot :-)
You may need to use the following instead...
.sticky-wrapper .header_row {
.sticky-wrapper.is-sticky .header_row {
background-color: rgb(17, 117, 55);
Thanks Ciaran, you took me in the right direction.
The follow code does the job
.sticky-wrapper, .header_row {
Greetings from germany
Would you have a URL to an example of the issue when your CSS is added to the Custom CSS field?
you will find the URL in the URL Field.
If you want the transparent background before and after scrolling, you can add the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
.header_row {
background-color: #0000004d !important;
If you only want it before scrolling then simply remove the !important.
sorry but its not work - have a look.
