1. cedrea
  4. Monday, 22 January 2024
I have installed the Joomla 4 Jasmine template and I have the following error messages :
Deprecated: htmlspecialchars(): Passing null to parameter #1 ($string) of type string is deprecated in /home/clients/d32a40efa90204bea0ba1ed8dc42a14c/sites/http://anne-ferrand-therapie.fr/modules/mod_j51icons/mod_j51icons.php on line 24
same problem for
mod_j51numbers.php
mod_j51testimonials.php
lines : 23 / 24 and 25
can you help me solving the problem ?
Hello sent by email
We will take a look now.
We appear to be getting the following error when we attempt to access your site?..
Class "Joomla\Plugin\System\Skipto\Extension\Skipto" not found
I have completely uninstalled and re-installed the whole website, I have added Jasmine again and the problem remains
when accessing the template style it indicates has follow :
Deprecated
: reset(): Calling reset() on an object is deprecated in
/home/clients/d32a40efa90204bea0ba1ed8dc42a14c/sites/http://anne-ferrand-therapie.fr/templates/j51_jasmine/elements/googlefonts.php
Can you solve this ?
I have tested it
the problem remains....
Hello, I have found in other forum that the problem seems linked to PHP version.
I have modified the server alert to minimum
Now it works better
Thanks for your help
I will wait for a new PHP version, which should fix the bug
Great... thank you for the update :)
