1. DSWrights
  4. Friday, 18 February 2022
When upgrading to php I get the ettached error.
when I open the utf8.php file, it states this
* If string overloading is active, it will break many of the
* native implementations. mbstring.func_overload must be set
* to 0, 1 or 4 in php.ini (string overloading disabled).
* Also need to check we have the correct internal mbstring
* encoding
if ( extension_loaded('mbstring')) {
if ( ini_get('mbstring.func_overload') & MB_OVERLOAD_STRING ) {
trigger_error('String functions are overloaded by mbstring',E_USER_ERROR);
mb_internal_encoding('UTF-8');
What am I supposed to do?
Just to confirm that this is a template related issue, could you try enabling one of the default Joomla templates (Protostar) and see if the issue still exists.
Hi CIaran,
The error still occurs with the joomla standard templates.
Frauke
Have you checked if all extensions are also php 8 capable? Or whether all extensions are up to date?
on most pages they are all uptodate. But I don't kno how to check if they are php8 capable.
I do have the assumption that it could be AcyMailing but I don't get why it could cause this overload
the latest version of ACM is 7.7.5. (from 2/14/2022) After you have made a backup of your site, you can try deactivating this extension (DO NOT delete it!!) and then check...
Which extension is not php 8 capable, you will probably have to look at each one
(If it doesn't work under the cassopia template either, it may not be due to the J51 template)
Yes, checked the latest update, which I installed.
as of now, I am pretty sure that it has nothing to do with the template. Thank you for your help.
Thing is I NEED Acymailing, since I do a lot of mailings...
