1. ecweb
  4. Wednesday, 18 May 2022
When I try to install the joomla 4 demo installer of j51_emani I get the following error after entering the database credentials:
Duplicate entry '31-8' for key 'PRIMARY'
This is to an empty database.
What should I do to solve it?
I have just updated the Joomla 4 demo installer for the Emani template to the latest Joomla 4 version (4.1.3) which should resolve any issues. To obtain simply redownload your template from your Joomla51 Template Downloads.
Hi I have the same problem with the theme Jasmine (Duplicate entry '46-8' for key 'vch7p_user_usergroup_map.PRIMARY').
Version: 1.1.15. Please help, thank you
Hi Webmasto,
in this Jasmine Quickstart guide, the error is specifically located in the file:
installation/sql/mysql/custom.sql
The relevant line in your package is 2344:
INSERT INTO `#__user_usergroup_map` VALUES (...,(443,8),...);
The primary key of this table is (user_id, group_id), so if (443,8) already exists during import, Joomla throws the error:
Duplicate entry '443-8' for key 'PRIMARY'
A simple workaround is to change:
to:
INSERT IGNORE INTO `#__user_usergroup_map` VALUES (...,(443,8),...);
This way, duplicate mappings are skipped and the installation can continue.
Best regards
Grazie mille
