1. jodancer
  3. Thursday, 21 June 2012
I purchased the mountain pine template (nice template!) but I have an error in Firebug which does not appear when I change to another template.
The error is
$(this.options.id) is null
var links = $(this.options.id).getElements('a');
fustesgilabertsa DOT com/prueba/
How can I fix this?
Many thanks
Hi jodancer
Would you have a URL to an example of the error?
Hi Ciarán,
Thank you for your reply.
I didn't get a notification of a reply and I can't find a "Subscibe" to this topic choice, so I have only just seen this.
The url is in the first post (I didn't want to link)
(oops Just seen the unsubscribe button, but I didn't get a notification)
Sorry jodancer.. hadnt noticed the URL in your first post.
May I suggest adding moomenu to the Menu Tag ID field within your hornav menu modules parameters (Extesnions -> Module Manager -> [YourHornavMenuModule].
Thank you Ciarán!
Fine now.
I have noticed that this is in the image for the configuration of the Horizontal Drop down Menu in your PDF instructions but as I wasn't using a drop down I hadn't looked at it as I didn't think I needed to!
Many thanks again
