1. DNA
  3. Thursday, 05 May 2016
Hello, I used your J51 - Boutique for http://www.notaioresciniti.it
I have a problem with administration system. :(
After open and close or save, or save and close an Articole, module, plug-in.... options... All
the system can't open again with [color=#ff0000]error: you are not permitted to use that link to directly access that page[/color] but I'm a Super User......???
I have de same problem when I use Advanced Module Management in front end.
Can You help me?
As before try extensions >> extension manager >> database (tab) >> fix. Also try clearing any cache if set.
Hi Ciaràn
Sorry for delay
I'm tested more solution but does not change nothing.
I found the problem.
When I use Joomla in my project I modify htaccess file to increase the page download with control cache and Gzip.
It's this change the cause of the error.
Thank you for the update and for sharing your solution! :)
