1. Rayjak
  4. Wednesday, 06 July 2022
0 - Using $this when not in object context error with Cashmere template
is the error message when displaying a gallery. Works OK with PHP 5.4. Just updated to 7.4.3 Works OK with Beez template
  1. https://porcelainpaintings.com/porcelain_paintings/index.php/test-sigp
  2. https://porcelainpaintings.com/porcelain_paintings/index.php/2022-07-06-22-10-04
Is the issue present if you disable your gallery extension?
The website works. It only doesn't work with the Simple Image Gallery Pro. It works using a different template which I really don't want to use https://porcelainpaintings.com/porcelain_paintings/index.php/2022-07-06-22-10-04. I have the extension working on another website using SP Page Builder and a different template. Using SP Page builder on the website in question with the Simple Image Gallery, I get the same error. By the way, my favorite template of all time is Cashmere. Hope it works on Joomla 4
Just tried Harmony and get this error:
An error has occurred while processing your request.
You may not be able to visit this page because of:
an out-of-date bookmark/favourite
a mistyped address
a search engine that has an out-of-date listing for this site
you have no access to this page
0 Using $this when not in object context
Go to the Home Page Home Page
but it works with the default Beez Joomla template.
The J51 Grid Gallery works on the home page. But, when an item is clicked, I get the same error: 0 - Using $this when not in object context
Hi Rayjak
That definitely seems strange. May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
Email sent to info@joomla51. Thank you.
I need to move on this. Client getting upsetp. I am restoring the website back to PHP 5.4 so it works. And will try to figure out something going forward. I think the issue is the template since the current version of Beez works.
Hi Jack
I did reply to your email. I will repeat our reply here....
Your admin folder appears to have htaccess protection. I have tested the details provided and they do not appear to allow us access.
