1. smithjd44
  4. Tuesday, 16 June 2015
I have a project started at the link: http://192.185.157.212/~starrec where I am trying to change the article background color to #FFFFFF .
I am having problems of finding where to make that setting.
When I try to set the article background color, that's not the color I am getting.
I would appreciate any assistance.
Thanks!
James
Hi James
Using a spot checker your current article background color appears to be #FFFFFF. Have you since amended this issue?
I solved the issue of the article background colors by deleting the code from line 751 - 760 in the #container_main.wrapper960 in the nexus.css.
This code created an article background color other than #FFFFFF even though I had set the background to #FFFFFF in the template parameters.
I am not certain the intent of this code but it altered the background color such that when I had images with a white background, they would show up against a darker background because of the above code.
You can go back to the website at http://192.185.157.212/~starrec and view the change to a pure #FFFFFF background color on the website.
Thanks!
James
Hi James
Thank you for the update and for sharing your solution.
By default the component area of our Enterprise has a slight gradient overlaying from top to bottom.
Hi Ciarán,
Any way to get rid of a space that appears under pics I have in the showcase position? Please see attached screen shots. I will send my temporary login in a private email.
Thanks,
rita
Hi Rita
The issue appears to be related to your image been placed within paragraph tags which has a bottom margin by default. To resolve try adding the following to the Custom CSS field of your templates parameters...
.showcase p {
margin-bottom: 0;
It worked! Thank you again. -rita
Is there custom css I can apply to remove the gradient from the article background?
thanks
Try adding the following to the Custom CSS field of your templates parameters...
#container_main .wrapper960 {
background-image: none;
