1. avarua
  4. Monday, 17 February 2020
i have removed the original Picture on top of the page and want to use the showcase position with the slider instaed.
but the position is not really on top. there is a big gap under the menu.
guess, that i habe to correct the posion in css, but i cant find anything.
I had found somewhere something with -138px but this was marked as inline. means, that i must change this in the normqal Template-Backend.
But i couldnt find anything.
Please help! :o)
Link_ http://web21.barney.kundenserver42.de/yc/
There was a failure in the Template.
Ciaran fixed it.
Download the new Version on the Homepage an install it like a Plugin.
Then it works.
Hello, can you tell me a comment you made? because I am looking for this solution.
As you do not appear to have a slideshow other pages, would you consider setting a dark color to the header background. This would make your header items visible.
Thank you for the access details however it appears your admin folder is password protected.
OK, i found the reason for the Homepage.
There was a extra modul in white on white.
Hard to see ;)
But on other pages the menu is still on white.
I have sent you the access-details.
The problem is also on other pages.
If you go down a little bit there is the news-module.
Klick at A380.
The Menu is not shown in the right way .
Yes, it is set to yes. And doesnt work.
If i set it to no, the gap will be more bigger.
To confirm I understand you correctly. You wish your logo/menu to display over your image? Have you tried enabling the option Overlap Header if in showcase-1# module position in your slideshow module settings?
