1. AlisonAMG
  4. Friday, 14 April 2023
Hey Ciaran
The Ensley Demo install pkg needs a tune up. It throw this issue upon load. https://github.com/joomla/joomla-cms/issues/38474
An error has occurred.
0 Class "Joomla\Plugin\Behaviour\Taggable\Extension\Taggable" not found
Not a warm fuzzy to get.
Just a heads up,
Ali
As far as I can tell, it has nothing to do with "your" template, it's a joomla thing...
you found the solution yourself
Link: https://www.joomla51.com/forum/class-joomla-plugin-behaviour-taggable-extension-taggable-not-found
Hey eumel7
Because I was installing the Quick Start Demo it makes little difference to the user. Yes it's a J issue but it is affecting the package deployment.
Short strokes - When I buy a template I want the quick start to work. I was letting Ciaran know so it can be corrected and someone who couldn't get past it doesn't bail on J51 templates because of a bad experience.
Alison
Thank you Alison
We have added a fix for this issue to our build scripts so it should automatically be fixed with each template update. I had thought this template had been updated since the fix was added to the script but just in case, I have rebuilt the template download so all should be now ok.
Thanks again
Thanks Ciaran
You make a great product and would hate to have someone turned off by a silly glitch.
Have a great day,
Alison
