1. birgitsax
  3. Saturday, 26 September 2015
I have a problem regarding my site - I have set the header to transparent and now when I scroll down, the content is going behind the header. Will send you the link to the website in an email.
Thanks so much for you great support here. Really appreciated.
Regards B
Hi B
Without a color/image in your header, any content which scrolls behind it will always be visible. Would you like to be able to disable the fixed positioning of your header items so they scroll with the rest of the page?
HI Ciaran, thanks for your fast response. Yes I think this might be the best option then. Thanks.
Hi B
To do so remove the following from your templates scripts.php (../templates/j51_enlighten/php/scripts.php - line 9)...
<!-- Sticky Div -->
<script type="text/javascript" src="/<?php echo $this->baseurl ?>/templates/<?php echo $this->template ?>/js/jquery.sticky.js" charset="utf-8"></script>
jQuery(window).load(function(){
jQuery("#container_hornav").sticky({ topSpacing: 65 });
jQuery("#container_header").sticky({ topSpacing: -20 });
</script>
Thanks so much Ciaran, works great.
As always - great support!!!
