1. jascanio
  4. Monday, 15 June 2015
I've set the joomlas's search module to be displayed in header-2 position. However the box comes out behind the main header.
I have Header Background set to a given colour and opacity to 1, but would not like to add transparency to Header Background, as I would loose the colour. Is there a way to bring search box to top?
You can reach my web here, should you need to have a look.
Thanks in advance for your help.
Regards,
Juan
Hi Juan
To bring your header-# modules to the front you can add the following to the Custom CSS field of your templates parameters...
.header-1, .header-2 {
    z-index: 100;
To better position your search field maybe use something like the following...
.header-1 .search, .header-2 .search {
    right: 17px;
    top: 91px;
.search .search-query {
    color: #fff;
Hi Ciarán,
Done. Thanks a lot!
As usual, superb support.
Regards,
Juan
