Thank you for your reply!
The option that you have provided in your reply did not sound very convincing!
I have memberships from other joomla theme clubs and this is not the problem with the themes that I purchase from them. Please visit my own company website [url]
http://www.lunaritsolutions.com[/url] and click on any link from the main menu on any device, you will see that you will be redirected to its respective page without any problems. I have just checked another theme designed by you called 'Habitat' and it also has the same problem; so, I believe there is bug in the way you are coding the navigational system into your templates which needs to be fixed.
However, I would be open to take your suggestion if the child link did not show in the desktop version of the template and only showed up on the mobile views.
So, will you be able to offer a solution to this problem with your template?
Thank you!
Kind regards,
Saeed
