I have a 3rd party slideshow at showcase position. The slideshow has some animations. When in transition from one slide to another, if a hornav menu item is dropped down over the slide, this goes hidden until the transition ends.
Any advice will be appreciated. (If you consider this is a slideshow's issue, please let me know and I will contact that extension's provider).
Thanks in advance for your time.
You can visit my web here. When prompted, please enter user: ciaran, pwd: ciaran51
Regards,
Juan
