1. jascanio
  4. Monday, 15 December 2014
I've set my modules blocks to "Yes" for responsiveness.
When viewed from a mobile device I get sidecol modules displayed before articles. Is there a way to make sidecol's modules to be displayed after content, instead of before?
thanks in advance.
Regards,
Juan
Hi Juan
To change the stacking order of your side column modules try adding the following to the Body Custom Code field of your templates parameters...
jQuery(document).load(jQuery(window).bind("resize", listenWidth));
function listenWidth( e ) {
if(jQuery(window).width()<959)
jQuery("#sidecol_b").remove().insertAfter(jQuery("#content_remainder"));
} else {
jQuery("#sidecol_b").remove().insertBefore(jQuery("#content_remainder"));
jQuery("#sidecol_a").remove().insertAfter(jQuery("#content_remainder"));
} else {
jQuery("#sidecol_a").remove().insertBefore(jQuery("#content_remainder"));
</script>
Hello Ciarán,
Thanks for your reply.
I have pasted the code into the Body Custom Code field, replacing s-cprit with script and j-avascript with javascript, but sidecols remain before articles when accessed from movile dvices.
I cleared joomla cache and waited for a couple of days just in case I had a server-wide cache.
Any idea?
Thanks in advance.
Regards,
JUan
Hi Juan
Hi Ciarán,
Thanks four your reply.
As requested, I've sent access details.
Regards,
Juan
Hi Ciarán,
Have also sent admin url, which was missing in my previous mail.
Regards,
Juan
Hi Juan
Thank you however we are repeatedly getting a timed out error when we try to access the URL provided. We will try again later.
Hi Juan
Sorry to say we are still unable to access the URL provided (timed out).
Hi Ciarán,
I see that I mispelled the url than I sent you, adding a double "/" before "administrator"
Let me know whether your login attempts were to this incorrect url or, if you realized and corrected it and, despite of that, you get the time out.
(Sorry about that)
Thanks in advance.
Regards,
Juan
Hi Juan
Yes we had noticed the error and removed the double slash. Strangely we are prompted for the 'first' username/passwords but after that nothing?
Hi Carán,
I've sorted this with my hosting provider. You should be able to access now.
Sorry for the inconvenience.
Regards,
Juan
Thank you Juan
We used the method described in the following post which has worked without issue... http://www.joomla51.com/forum/8-commercial-templates/5068-calibra-changing-the-responsive-layout#9990
Hi Ciarán,
Thanks for your reply. Your solution works a treat!
One final doubt. I see that Custom Code / Head Custom Code field, has the code you firstly recommended on post #13833.
I understand I can delete it now, once I have modified main.php. I have deleted it and everything seems to remain ok.
Am I right?
Regards,
Juan
Hi Juan
yes you are correct in removing this code as it is no longer required.
Ok. thanks for your help
Regards,
Juan
