1. joonchen
  3. Wednesday, 25 May 2022
The Slideshow TEXT shows perfectly on any PC browser. The Slideshow itself is perfectly responsive. But for some reason the TEXT it doesn't show up on a mobile device (iPhone 11 Pro). Any hint?
Is there an option to have the text with no animation just on mobile view (with animation for PC browser view)?
I will send you the access details to your info mail, with a link to this post. Joomla v4.1.4, J51_LayerSlideshow v1.1.10.
Any hint is much appreciated. Thanks.
Using the Custom CSS options in the Responsive Options tab of your template style settings try adding the following to the screensizes where you wish to disable all transitions..
.layerslideshow * {
transition-property: none !important;
transform: none !important;
opacity: 1 !important;
Sorry, I found the "solution" for the hiding text, under the "Responsive Settings". No problem. But is there a way at least to have the text to show up with no animation in mobile mode?
There is another issue when viewing a EMANI-template-site with a mobile phone: the Language Switcher shows up, but is not working. No problems in a PC browser. But in mobile view mode the dropdown is not working. In mobile view mode you can't switch languages.
Any help is much appreciated. Thanks!
Hello, any help, please?
Regarding your mobile menu issue, may I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
I notice you have already shared your admin details. Taking a look now.
It appears the details shared is for a site without a language switcher. Would you have a URL to an example of your language switcher?
I can confirm, issue with setting in Responsive Options tab is solved.
Is also somehow possible remove from the picture the small boxes in right bottom corner? I got a complain about it.
Thanks a lot.
Petr
Would you have a URL to an example of the small white boxes in question?
