1. joonchen
  3. Monday, 23 May 2022
I bought the EMANI template for its brilliant design. Thank you!
I already created a multilanguage website under Joomla 4, with 3 languages. The Main Menu with its parent items is working without any issue in all 3 languages (hornav enabled). But when adding a child item, the dropdown doesn't work at all as expected (as shown in the EMANI demo installation). Please see screenshot attachment.
I followed this tutorial: https://www.joomla51.com/tutorials/template-extras/adding-a-module-to-the-menu-dropdown, but that didn't work.
How can I make the dropdown work? I will send you the login details to your info@... mail address, as my site is currently in development mode (offline).
Thank you for your kind support.
Regards.
  1. https://iustitia.com
SOLVED!
I found the solution. Click on the Main Menu > Advanced > Layout > choose "Default" (From Module).
Sorry for bothering you Ciaran! Thanks.
Good work and thank you for sharing your solution :)
