1. EFH
  4. Wednesday, 04 September 2024
Just checking if I can update the Emani template to the latest 5.1.4 version of Joomla?
I purchased version 4 but it says that it is compatible with version 5, not beyond, so i am just checking before updating, please confirm.
if you have downloaded the latest version of the template it will run smoothly.
Do I just upload the latest version onto my existing website in joomla CMS?
http://www.luxeentertainment.com.au
I am having problems trying to update the template according to the tutorial.
I have two websites to update and both are currently using Emani version 1.1.10
Are you able to assist?
I also received this message:
JInstaller: :Install: Can't find Joomla XML setup file.
Hi, would REVOLVE work with Joomla 5.1.4 ? Trying to install demo, but getting the same message all the time: JInstaller: :Install: Can't find Joomla XML setup file.
Please, I need some help, stuck with it for 2 days. Thanks
As mentioned have you checked the tutorial on this topic (https://joomla51.com/tutorials/troubleshooting/error-cannot-find-joomla-xml-setup-file). It sounds likme you are trying to install the demo via an existing Joomla installation which is incorrect.
EFH
Thanks for your reply. I have just emailed you.
Thank you Slavica
The latest template download has been installed to each your sites.
