1. Burnardo
  3. Tuesday, 17 June 2025
Hi, On my localhost server I am building a multilanguage website. The template is based on Emani (joomla 4). It works fine and even an upgrade to Joomla 5.3.1 has proven to be flawless.
There is still one issue remaining that I am unable to solve.
Using the J51_Testimonials module works for some 'positions' and pages, but on other 'postions' and pages the script does not seem to load or be present, causing the module to behave 'static' as opposed to the 'rotating' feature as it should.
Apparently the tiny_slider.js script is not loaded on all pages or positions as it should.
Furthermore there is a "Uncaught ReferenceError: tns is not defined" visible.
On other forum discussions, this has apparently been solved. Unfortunately I am using a local server for this instance
How can I fix this issue? Or, can you hand me some details on fixing?
Version information:
The version of the J51_Testimonials module is 1.0.4.
Emani template version 2.0.0 is used
PHP version: 8.1.31 on a local WAMP server is used
And, as said, the Joomla version is upgraded to 5.3.1
Latest news:
Managed to solve my issue, by installing the J51_Carousel module and changing the custom.css in order to show the desired items in a right way. Now the J51-Carousel is acting as a replacement for the 'second' (and not rotating) J51_Testimonials module.
Thank you, Ciaran,
For the moment I am perfectly fine with it, after the adjustments.
But, good to know the possibillities.
As mentioned under "Latest news", my solution by implementing a different module and further adjusting this J51_Carousel module also works for me.
Unfortunately I am only using a local server to work on this website, so sending temporary administration details does not work in this case.
I had been hoping for a guide to use multiple instances of the J51_Testimonials module.
Thanks for your reaction, Ciaran.
If you find the issue is still present when your site is online, reach out to me and I will take a look and see what may be causing the issue.
